In case anyone is interested, I have been writing this up day by day. I thought I'd share it here with some photos.
First things first; there's a satellite tracker on the airplane that can be viewed at https://share.garmin.com/katamarino
My loose plan was to spend ~6 weeks total flying from Pittsburgh PA to Alaska, all around Alaska and Northern Canada, and then home. The rough route as initially planned can be seen here:
The aircraft is a 1982 C182R with PPonk engine. Panel is as shown. Highlights are a 430W, Stec-30 with altitude hold, and EDM-830 engine monitor. Also my new G5 to replace the failing AI. There is a certain amount of "GPS overload". The two in the panel came with the airplane. The Aera 550 on the yoke I find very useful for looking up ADS-B weather and airport info; the interface is better than with Garmin Pilot on the tablet. The tablet is, however, extremely useful for holding all the IFR charts/plates, and has more detailed and up to date airport info than the Aera, so they all play a role.
I set off mid-June, flying my old C172 up to Williamsport PA to collect my new 182 which had been in the shop there for a G5. I'd also added Flint tip tanks for an extra 23 gallons usable, and a dual USB charger in the panel which is proving to be very useful indeed. As is often the case the work went down to the wire and was only finished the day I wanted to depart.
The weather was IMC through PA and OH but then cleared right up. I just flew hard to cover ground across the "boring bits", and made it to Creighton Municipal in Nebraska to camp overnight.
The boring bits:
Overnight in Creighton:
The view from the tent:
The boring bits:
Cessnas have feelings too!
