I'd booked a beacon slot and planned 2ish hours of IFR practice in our PA28 shareoplane. We have an electronic carbon monoxide detector in the cockpit.
Pre-flight, I had a slightly higher than usual CO reading - around 11ish, not abnormally so as it often shows around 8, clearing quickly to zero after take-off, so I noted it, and proceeded with the flight.
Just after take-off the CO detector alarm went off showing 26ppm. I experimentally unclipped it and held it by the open DV window - dropped to zero. Put it back on the clip, went back up to 26, alarm went off again.
So, re-opened the DV window, and the side vents, called the field, did a circuit, landed, snagged the aircraft. Block time 18 minutes, airborne time 6 minutes.
Myself and another syndicate member opened and thoroughly went over the engine compartment - no cracks, loose joints, etc. visible anywhere. Spoke to the pilot who flew it last - he saw a slightly elevated 11ppm four days previously but hadn't been concerned.
So, aircraft grounded until maintenance can go over it. Some thoughts...
- It's an electronic device with a good clear audible alarm.
- 25-30ppm is reckoned okay for an hour (WHO guidelines). However I was planning 2hrs, mostly around 3000ft, likely in and out of cloud, so high workload, increased dependence upon my ability to function procedurally.
- Also, I got over covid a month ago and whilst back at work and flying, I'm aware of my lung capacity being significantly down (not that I'm physically incapable, but the week before I had covid I was running 30 miles a week, typically 5-7½ miles at a time, recovering afterwards in the time it took to drink a cup of tea - I'm presently struggling to achieve 12 miles a week, maximum 3 miles, and taking hours rather than minutes to get over it, so by *my* standards my fitness is somewhat degraded).
- A bit of googling suggests that people recovering from Covid arealso poorer at expelling CO, which suggest possibly to my uneducated mind an increased risk of CO poisoning?
We'll get to the bottom of this in January I think, lose a couple of weeks when we might otherwise have been doing a bit of pleasant flying.
But it's just possible that small loud electronic carbon monoxide detector just saved my life. As it is, we're mildly inconvenienced.
